? about sensored motors -
10.12.2009, 04:18 PM
Do all sensored motors use the same sensor wire plugs? Or are they all different?
I'm wanting to use the MMP(when available) with a Novak Ballistic 17.5 turn motor. Any problems?
2 KiloWatt RACER
10.12.2009, 04:47 PM
They are pretty much standard across the board.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
10.12.2009, 04:55 PM
Ok, was making sure they would all work.
Any input on the Novak Havoc Pro esc and ballistic motors? I may head that way if the MMP isn't release soon enough. I need to get my SC10 on the road.
2 KiloWatt RACER
10.12.2009, 05:08 PM
There is always the Tekin RSpro, but MMpro requires no mods to have fun with.
10.12.2009, 08:00 PM
Ill recomend the tekin rs systems to anyone for a 1/10th electric they are awesome! I run the tekin rs 8.5s in my T4, J82, and Sc10 and i love them.
not good luck around here with the 1/8th rx's
but im looking forward to trying the MMpro
10.12.2009, 08:07 PM
I would love to try the Tekin RS systems. But they are so damn expensive... I'll be running a Redline 17.5 motor. I just picked one up. But I'm still debating the RS... Unless I can find a good price on one. How programmable are they? Like Castles?
I wish the mmp's were shipping already. I need my setup for the 22nd, got a big local race.
10.12.2009, 08:18 PM
the rs is worth it! and its very adjustable and witht he newest software in sensored only mode the Boost will REALLY change a motor, the rs can take an 8.5 and make it pull 6.5s outdoors and run like a 13.5 indoors.... so adjustable and INcredibly smooth.
10.12.2009, 08:20 PM
Hmmm... may have to get the RS...
10.12.2009, 08:30 PM
Well I picked up a Tekin RS, not the pro model. Only running 17.5t motors as per ROAR rules for Short course.
And is the Hotwire really necessary?
10.13.2009, 12:36 AM
yes the hotwire is a nessicty, when you get the hotwire put it on sensored only mode and crank that boost up, gear that sc10 right and watch the other sc's eat roost, you should see a solid advantage using the rs.
10.13.2009, 12:53 AM
I knew I should have ordered the Hotwire... Hopefully the LHS has one.
We have a big race on the 22nd. I'll be running Slash Spec and SC Truck with my SC10(RS/Redline 17.5/ Hyperion 2s 5500).
10.19.2009, 12:04 AM
A friend of mine is trying to run a Trinity Duo 2 17.5t motor on a CC Sidewinder in his SC10. From a dead stop, the motor cogs bad and cant decide whether it wants to go forward or reverse. But if you give the truck a push, it will take off and run until you hit a dead stop again. Any clue? The motor is supposed to be able to be ran sensored or sensorless. Or is it a must to run it sensorless?
