redshift
RC-Monster Square Tube
redshift's Avatar
10.20.2009, 08:23 PM
I was just reading that you may want to pick up a Class 4 MicroSD card. The class has nothing to do with capacity, it is how fast it can be written on. This is a cure if you find the video jumps or is jittery.
I did forget about the early reports of the included mSD card being junk, and from what I've seen so far that is the main reason for the recall.
And yes the card class seems to matter with this one. A faster card obviously won't turn 15fps into 30fps if the cam is only capable of 15.
But too slow of a card can effectively reduce your framerate. I already had a Sandisk I was using, I failed to mention that
I have to say I am more impressed with the keychain cams, at least the better ones. Overall they have better video, and being so compact gives you unlimited mounting options.
I guess I will continue to use my Turnigy cam and see what develops...
