J57ltr
10.23.2009, 08:20 PM
I really don't think any firmware change is going to affect the BL rpm sensor. I use a mm and it has almost always done this I have gotten it to work a few times but most of the time it's at the limit of max RPM set in the software for the eagle tree or it's at zero rpm and just jumps around. I have tried everything except actually shielding the cabling to the sensor. I even soldered a twisted pair from 2 of the phases and put a connector on it so I could plug and unplug it and get it away from the motor. It still does the same thing.
I installed the magnets in the differential of my Rustler and installed the Hall Effect sensor in the Transmission case and it does not seem to work correctly either, but that may be a setting. It just goes to 750 rpm and stays there.
Jeff
