The LST XXL diffs I got on ebay all had the Team Losi Heavy-Duty Differential Case which use metal thingies for the shafts of the spider gears. These diff cases are the same cases used for the Losi SmartDiff. The LST and LST2 diffs I worked with used the stock Team Losi diff case.
No brain, no headaches.
