10.31.2009, 11:18 AM
Just gear it down if it is too fast... 1850kv on 6s is fine, and you may find that the higher motor rpm coupled with lower gearing is actually more efficient than lower rpm with taller gearing. Lower gearing equals less load. I can imagine it will have a snappy bottom end, but you can tame that with esc settings if necessary.
I found that the cc 2200 motor on 5s lipo (44k rpm or so) was very efficient in my lst. To be honest it may be almost as good as the 1521 1y on 6s (less than 39k rpms) and the lower torque levels made it easier to drive. Most motors have a sweet spot, never found that spot with medusa motors, so i gave up on them and went back to neu. No experience with tekin motors, but I still think the neu are the best available with the cc 2200 coming a close second!
I had a few medusa motors in a buggy and they all ran too warm for my liking. There is no comparison to neu, and the motors were not that much cheaper. All of the materials were a few steps down on the medusa motors, you got what you paid for.
10.31.2009, 11:24 AM
Just gear it down if it is too fast... 1850kv on 6s is fine, and you may find that the higher motor rpm coupled with lower gearing is actually more efficient than lower rpm with taller gearing. Lower gearing equals less load. I can imagine it will have a snappy bottom end, but you can tame that with esc settings if necessary...
I completely agree.I run a Neu 1512/2d (2550kv) on 4s which puts my rpm at just shy of 38000 rpm and love it. When geared down it has tons of snap and the ESC is seeing enough motor revs per mph so cogging is nonexistent at any speed. Yo0u may find the motor getting warm if you wind it out at top speed and keep it there though, so just play with gearing.
Or, since the motor is new and unused, see if they will swap it out for a lower kv. Explain the misunderstanding and see what they say.
FG101C
10.31.2009, 11:38 AM
Ok, thanks guy's, I will play with it before I decide my next move. Would have been nice to screenshot that original chart, but who would have thought. BrianG, the speed calc shows 1350 for the 2y, I guess it's 1380 now, and there's another one showing 1500 that Neu is showing 1475. Not much of a difference, just thought I'd let you know.
Thanks again.
FG101C
11.01.2009, 07:40 PM
Well I'm happy to report that whatever kv the motor is it is perfect. Probably the best setup I have ever ran. Motor temps were 125 degrees, battery and esc were warm at best. It has plenty of bottom and plenty of top and run time was right at 20 minutes with a 3600mah 6s pack.
