Thread Tools Rating: Thread Rating: 50 votes, 5.00 average. Display Modes
Riko
Riko's Avatar
10.31.2009, 12:45 PM
so when buying the LE + the RCM kit, you have all the parts you need
You've been hit by, you've been struck by a smooth criminal
  Send a message via MSN to Riko
NIX
NIX's Avatar
11.01.2009, 03:53 PM
Yes, I would go for that.
6s setup with a 1300 - 1700 kv Neu 1515 & MMM V3 for when you are living in the US. Medusa 36-70-1600 kv would also be a good motor to start with although medusa has passed away....
For europe I would suggest to buy a MGM compro 8s 140 A controller directly at MGM compro. http://mgm-compro.com/index.php?cat=...for-cars-boats. They have a quick service and 2 year 'idiot proof' warranty. Price difference is just a few euro with a MMM V3 over an official agent. A very nice option they have now is a complete waterproof ESC!!!!! No fans needed on these 'though' boys. I am very pleased with the service and feedback on questions etc of MGM compro. I myself use both 2 160A 6s and 1 140A 8s MGM compro controller.
Lehner 1950 or 2240 series would also give terrific motor and can be ordered directly at Lehner.. http://www.lehner-motoren.de/ms22.php.
I would advice to use a UBEC (castle creations) as a bec is like a little heat source in every controller. A good setup with a decent esc doesn't need a fan.... For that a 6s for a truggy gives a much more reliable, efficient and cooler setup than one on 4s. 4 s for a buggy I see as a minimum and for the fact that a truggy is heavier 5 s seems to be the minimum to choose for, so go for 6s.
I see no need for using a sensored system.. Buggies & Truggies are to be driven.. not to use as crawler... I've no 'cogging' issues with the lower kv / higher voltage setups.
Althoug big I noticed that the hobbywing 150 A controller (also at RC-monster available) does a very good job. A friend of me has 'fried' ad MMM v3 is waiting already more than 3 months (yes 3 months!!!!! wat about customer service of ?Castle Creations for european customers... because of that MGM compro is the controller manufacturer to buy in europe, service = 10 days max!!!) for the replacement and is meanwhile running a hobbywing EZrun 150A. It runs without any problem and seems even to run more smooth than the MMM he has (but is waiting for to return...).
Byte
11.01.2009, 04:53 PM
Where do you find those Waterproof versions?
I always asked myself what the difference is between the E-Series and Z-Series. The only thing I know is that the Z-Series are newer than the E-Series, right?
NIX
NIX's Avatar
11.01.2009, 05:27 PM
The waterproof version is an option you need to ad to the ESC once you picked out the rigth one. http://mgm-compro.com/prod_opts.php?...&prod_type=reg WR, water resistant version. A picture of this version is at the home/introductionpage of MGM compro. And yes, it also works under water... but other systems of your RC8T might fail to do.
The Z series has an extra port for adding a black box to log all data, for that somewhat more $$$. Otherwise equal so if you are not a 'tech freak' it is a waste of money.
