Jabe
11.05.2009, 04:02 PM
When you calibrate your transmitter, make sure your throttle is neutral.
Thing you described is fail safe in action. Just re-calibrate your receiver to transmitter and follow instructions!
I have Spektrum and VXL, and i continuously turn transmitter off first when truck tires are not touching ground to check that fail-safe.
Well im too lazy to take body off to cut power...
