shaunjohnson
i pwn nitro
shaunjohnson's Avatar
11.07.2009, 07:26 PM
in the coleman fuel area...
they use either zenoah 23cc engines or a copy on one.
both of these engines use a Walbro WT-644 carby.
these carbs are simple enough and will run a wide range of fuels.
but, the pump diafram inside it will not tolerate anything other than petrol on the stock seals.
there are other types of seals out there that can tolerate coleman fuel, methanol etc but they are a little hard to find.
i used to run a modded 28cc trimmer motor on my 1/4th scale airboat, that engine started out as a 1hp stock, it ended up pumping out over 5 hp from some basic mods and running methanol. i happened to obtain the correct seals from a different carb i had lying about.
now, yes sure, coleman fuel will work in your 1/5th, and it might be better performance wise.
over time the pump diafram and fuel metering diafram will be eaten away by the fuel and will cause much more damage than good!
  Send a message via MSN to shaunjohnson
