Go Back   RC-Monster Forums > Support Forums > Team Tekin
GO-RIDE.com
11.12.2009, 02:45 PM
I'm using 2.4. It's definitely comes and goes, but is often enough that I can't really drive the vehicle consistently. I'm just wondering if anyone else has had a similar experience with a RX8? My first RX8 just stopped working, but it seems this one is going out slowly.
E-8ight - Tekin RX8 2000kv/4S
whitrzac
Can't catch this...
whitrzac's Avatar
11.12.2009, 03:22 PM
does it happen after jumps, or just driving around??
does the steering cut out also?
is it overheating?
check
  • wires for kinks/brakes
  • loose solder joints
  • bad solder jab on the posts/motor
  • loose plugs on the RX/motor/batt
  • make sure the switch is working properly and not flipping off when jarred
  • cut wires(especially the RX plug, and switch)
  • make sure the sensor plug is all the way in(if using a sensored motor)
GO-RIDE.com
11.12.2009, 03:43 PM
It only happens at the track, which does have some big jumps. I did a bench test at home and then drove it around on the street for 15 min and it did not glitch, but hit a few jumps at the track and it's a problem.
I'll re-check all the wiring, but it looked good the other day. I think the PCB in the ESC is going bad and it's only a matter of time till it quits all together. Not a big deal. This one has not been in for warranty yet and it is a V1 of the RX8.
whitrzac
Can't catch this...
whitrzac's Avatar
11.12.2009, 04:22 PM
it might be the pot on the bottom of the lower board in the esc, there is a known problem with a solder joint coming loose.
5R6 chip on the bottom
