Go Back   RC-Monster Forums > Support Forums > Team Tekin
whitrzac
Can't catch this...
whitrzac's Avatar
11.12.2009, 03:22 PM
does it happen after jumps, or just driving around??
does the steering cut out also?
is it overheating?
check
  • wires for kinks/brakes
  • loose solder joints
  • bad solder jab on the posts/motor
  • loose plugs on the RX/motor/batt
  • make sure the switch is working properly and not flipping off when jarred
  • cut wires(especially the RX plug, and switch)
  • make sure the sensor plug is all the way in(if using a sensored motor)
