sikeston34m
sikeston34m's Avatar
11.14.2009, 12:02 PM
Originally Posted by J57ltr View Post
So Joe, have you checked out your servo?
sikeston34m, Yes you and Joe's friend are the other 2 I was refering to. What was wrong with your servo?
Jeff
I believe it was a factory defect. I took the servo apart and it's control board was burnt.
This tells me that I "over amped" the BEC inside the MM Pro, without damaging it.
I also believe the BEC has over amp protection.
As a servo's gears begin to wear, it draws more current. If a person is having problems like this, my advice would be to check your servo.
