Byte
11.15.2009, 11:19 AM
Originally Posted by hoober View Post
The smaller chargery one is ideal and a good bang for your buck. If you'll not want to max out your new charger then the first one you linked is fine (up to 100-120 watts0
Well, I would like to charge my 5S 5000mAh LiPo at 2C, so that first one won't be good enough. 21*10 = 210Watt needed. BrianG also said that it makes some losses (efficiency), so it wouldn't be enough to charge my 5S 5000mAh LiPo at 2C.
