It will work I was running a Sidewinder with 4s and CCBEC on a Novak 17.5 (~2200 kv). There was quite a bit of cogging at startup due to the gearing but once rolling it was pretty smooth. Now running a MM Pro though.
The Sidewinder was not designed for running above 3S. Some percentage of Sidewinders will NOT work at all on 4S. The BEC has a maximum voltage of 16.0V, 4S is maximum around 16.8V. Some percentage of the BEC chips detect an "overvoltage" condition, and shut the BEC output off.
Patrick del Castillo
President, Principle Engineer
i was planning on using an external BEC. can 4s be done WITH an external BEC?
