Rivermaxx
11.17.2009, 09:31 AM
My issue is I am making so much power that when I am on it and the tires just spin causing me to loose control. What good is that? I think if I used a higher kv, smaller less torque motor with higher numerically gearing I would be faster because I can control the car better better. Even with 100 % punch control with my setup it still will wheely if I hit it at a roll. My question is will the esc be able to handle the smaller higher kv less torque higer rpm setup better and be less likely to burn the esc or would it be about the same with the bigger motor less kv more torque motor. What I am trying to get at is you can have all the power in the world but if you cant put it too the ground without spinning the tires and going straight down the track what good is it.
