Thread Tools Rating: Thread Rating: 57 votes, 4.93 average. Display Modes
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
11.18.2009, 11:55 AM
I just tested two Turnigy 5000 mah 2S packs and here are the results.
Turnigy #A1 (in black)
Discharge rate: 10 A
Starting voltage: 8.44 V
Ending Voltage: 6.00 V
Total Time: 30 min.
Tested Capacity: 4996 mah
Turnigy #A2 (in black)
Total Time: 30 min. 29 sec.
Tested Capacity: 5076 mah
Here are the Turnigy graphs and NEU graphs overlaid for comparison.
These NEU and Turnigy lipos were not bought at the same time but they have similar use, the NEU lipos have 11 cycles more on them than the Turnigys. After the test, the Turnigys got recharged at ''store'' setting on my CellPro 10S with no problems. The NEU packs would not take a charge on the CellPro. I had to wake them up shall I say on my MRC 989, charging at 1 amp until they had about 1300 mah back in them and then switched to the CellPro and only then would they take a charge at the ''store'' setting. I'm a little bit disappointed at these NEU packs. Actually I'm very disappointed.
Any comments suggesting that the tests are bogus are welcomed
And please don't take this as a ''cheap lipos are just as good as expensive lipos''. This is not what it's about, I started using this CBA II thingy with the NEU lipos and I was surprised at their performance. So I thought I would try the Turnigys after, being a little bit afraid of what their performance might be. What can explain this? These lipos were used in the same truck, same gearing and settings, same racing and bashing conditions.
No brain, no headaches.
