I purchased and MC 1/8th Scale Diff!
rrgirgis
rrgirgis's Avatar
I purchased and MC 1/8th Scale Diff! - 11.20.2009, 09:10 PM
First off i want to say that MC is a great person to deal with, he answered all my questions about the 1/8th scale CD and even gave me tips and help on installing it properly.
unfortunatly i dont have access to the machenery required to complete the 1/8th scale diff but would have jumped at the chance to make one myself if i did
I purchased the MC 1/8th Scale diff and he shipped it out the same day, it came just as pictured in this thread carbon fiber disk and all. The diff itself when i got to look at it up close is made extremely well, all of the cuts and modifications needed to make the diff are top notch!
Just incase you are on the fence about getting one... DO IT! this cd makes a huge difference in my opinion. on to the reveiw!
WOW!!!! this thing is awesome! i filled it with 50k only, since i really only run 4s geared 18/54 and this is how a CD should work! it unloads a tiny bit to the front and will only wheelie if i from almost a dead stop punch it. this cd makes the truck handle so much better when it comes to onsteer push since its not unloading to the front causing the truck to lift the nose up, slide and not grip the ground. you can also see the difference when going in a straight line, it makes the truck hug the ground and stay planted not wasting that valuable mamba power!
I'm glad i made the investment this CD it is a must if you like going to the track, im sure i will be able to turn much better and clear jumps easier since i wont be unloading motor power to the front. Next test will be to see how well it holds up to all the abuse of brushless over time and at the track but i can say that this thing is beefy and looks like it would out far far oulast a stock e-revo CD not to mention work 100x better
thanks again MC!
