look for a good dremmel for x-mass -
11.21.2009, 05:54 PM
Building a x-mass list and need a good dremmel....I saw these at harbor freight...what do you all think? Is there another one you all recommend? Also saw their accessory kit as well..
I got a "tool shop" brand for $30 WITH a huge accessory lot and WITH the flexible shaft. (you gotta switch to the flexible shaft, no more hot tool in your hand{Linc? is this thing on?})
It was at menards and still running strong with LOTS of hours on it.
i agree on the flexible shaft is great, also as far as harbor freight and chicago tools, the quality is not that great especially on their bits and attachements. if you opt for the chicago tools dremel, use dremel bits as the one that come with it are pretty much junk. and dont expect much battery life out of the cordless as they use low quality parts and batteries. but if u are looking for a more affordable solution i would go with the corded model and use dremel bits.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
