11.22.2009, 11:04 AM
Originally Posted by Riko View Post
yeah okay but that movie shows how to solder it to a motor cables, but what I meant was how to solder bigger 6mm connectors to the MMPro wich has originally 4mm connectors...
if the ESC MMPro has prelocated space for 4mm connectors, how can a bigger connector be soldered on that prelocated space when that space is to small...do you know what I mean? :)
I dont mean to be rude, but are you really trying to tell me that because the wires are coming off the esc and not the motor, that you cant work out how to change the connectors with EXACTLY THE SAME METHOD?!?
1. REMOVE 4MM PLUG
2. REPLACE WITH LARGER PLUG
It doesnt make single bit of difference where the wires are attached to.
Like I said before, and has been said to you by several other people (all with more patience than me evidently...), it doesnt matter what size the wire is, you can always use a bigger connector simply by removing the stock ones- you just have to use the same size male and female ones on the esc wires and motor wires so that they match up.
Or like other guys said, you dont even have to use connectors, just direct solder the wires together with a butt-joint or butt-joint connectors to make a more solid joint. IS NOT DIFFICULT TO FIGURE OUT, YOU ARE OVER THINKING THE 'PROBLEM'...
EDIT:
See the 3 wires coming from the esc that have the 4mm plugs on & that go to the motor? All you have to do is remove them, and solder on the larger plugs- I dont understand what you are talking about with regards to a lack of space? The plugs are not on the esc itself, they are on the ends of wires- there is no lack of space available to put on larger connectors- you just need a little extra solder in the connector before inserting the wire to take up any slack & ensure a solid joint; exactly as I said last time.
