11.22.2009, 10:13 PM
Make sure someone shoves all this info under Jason's nose on whatever forum hes lurking on, love to see what his responce will be, if any. When he refuses to issue his own graphes and charge/discharge data, it'll be plain as day that MA are all mouth & no trousers...
lutach
lutach's Avatar
11.22.2009, 10:35 PM
MA could've done something like this: http://www.rcgroups.com/forums/showthread.php?t=1078049, but I think the MA boys don't know how to hack the graphs to make them look good and that's the reason they don't post anything. Here's a thread with good results so far: http://www.rcgroups.com/forums/showt...1143540&page=2.
sikeston34m post your info there and call out the MA guys to see what they can say about the reject cells .
sikeston34m
sikeston34m's Avatar
11.22.2009, 10:57 PM
Those guys are watching this thread. That's why they accused you and BN of playing games between there and "another" forum.
It's because they are watching this thread and the "60C really?" thread.
They are alot of "Talk". The proof is in the pudding.
That's why we should put these packs up against their "Green" packs on legit discharge equipment. Or at least an Eagletree running the same setup.
I really enjoyed seeing the discharge graphs in the link you posted Lutach.
I do believe these are holding voltage above 3.0 - 3.1 volts per cell right up to the very end. The discharge curve is VERY flat and at the end they drop suddenly.
I'm tempted to setup my E Revo with these also, then buy another Automotive charger.
Picture two Monster Trucks geared for 40mph, being charged in less than 10 minutes, only to do another 30 minute run.
It's a play all day kinda setup.
11.22.2009, 11:45 PM
Interesting, I have a really nice automotive charger at the shop, all digital. It has a 6v setting too... Maybe I should try the 2s pack on that? HeHe, it can do 60 amps... What does that work out to, 13+c....
Maybe stick to the 20 amp setting, that should still do the job in 15 mins. I am sure some of the plane guys will try a 3s pack with the "zip charging" method. That is basically a 12v power supply (A big one that can be set) and a certain length of certain gauge wire to limit the current. One guy was charging the 2300 cells in 3 or 4 mins....And had hundreds of cycles as well.
sikeston34m
11.23.2009, 12:05 AM
The 6 volt setting should work fine for 2S.
Recommended charge cutoff is 3.6 volts per cell.
I opened up my "Black and Decker " automotive charger and soldered a "little" 16 Ga. lead directly to the outputs on the board.
The cells topped off right at 3.55 volts per cell. Slight Calibration error, or added resistence in the lead? Not sure, but it works perfectly.
My advice is, make sure your charger terminates charge on the 6 volt setting at 7.2 volts or less and you're good to go.
Wait a second! I'm sure if you "surf" the net, you could find a "GREEN" Lifepo4 charger for $567,789,234 Gazillion dollars!
It's the BEST too! Much better than all those other "reject" chargers!
76Bentley
11.23.2009, 02:28 PM
I am glad to see you guys talking about these, I have been wanting a set of LiFe for my E-Maxx that does not have lipo cut off. I had wondered about these, they seemed almost to good to be true, considering the amount a certain website that advertises a lot wants for theirs......
11.23.2009, 02:37 PM
For 50 bucks a pair plus shipping you can hardly go wrong, half the price of ONE pack from the competition...
76Bentley
11.23.2009, 03:00 PM
I was wondering though if these were way out of balance like you hear about with some of the less expensive lipos. Also James when you get a chance to run them, please comment if you think of the claimed discharge rate is accurate.
11.24.2009, 11:54 AM
Not way out of balance- as Sike stated, they come well balanced and maintain a good balance, within .003 volts after charging. They certainly arent reject cells like MA would like you to believe- thats called a smear tactic to make you mistrust them, and instead buy their insanely overpriced versions (that are more than likely to be the exact same cells/ from the same factory...). Have faith
76Bentley
11.24.2009, 12:39 PM
Neil, I totally agree with you, was looking for James' input as well as he knows his batteries. Plus his set is likely out of a different batch as well, so I thought if several people chimed in that have them it would be interesting. I plan on ordering me a set in the next few days, I just don't have the experience or ability to test them myself or I would try and add too.
I thought Himalaya really hit the nail on the head on page 4 talking about that the cells are graded, but if they were to far out of tolerance they would need to check the production line. I think this is an excellent point since MA claims they are "rejects". I remember in college I had Production/Operations/Management where this was discussed a lot. With many if not most products like batteries made there and sold around the world they have come a long way in terms of quality, they had too. And while we here focus on the batteries that apply to us as far as RC goes, they are in tons of products. Lap tops, cell phones, hand held video games, PDAs,........and so on. Anyway long story short, that reason given by MA just doesn't cut it any more in the global market place.
jpoprock
jpoprock's Avatar
11.24.2009, 01:27 PM
So, let me get some clarification about these packs... cuz I'm about to maybe buy two of them for my Emaxx w/ EVX2. These packs will be fine, maybe a bit slower than say a 5000mah 2s 40C Zippy, but they don't need balanced, and I won't need an LVC or battery alarm for them?
My Hyperion will charge them, so that's not a problem. I was just wondering if there was any REASON I should buy a couple of these over some Zippy Lipos... if not just to "try"? I'm sure I'll be happy with them though. it's not a matter of money really. It's more about, "Gee... maybe the slower speed will be ok in trade for convenience?" I don't find Lipos to be inconvenient though.
Another note.. i'll be running these and the lipos in snow.
Oh, and with Life packs... I can charge them super fast right? And I don't have to balance them. I charge my lipos in sync mode if running two of them. I won't have to do that with Life packs? Or does it matter?
  Send a message via Yahoo to jpoprock Send a message via AIM to jpoprock
11.24.2009, 01:35 PM
LiFe cell = 3.7v fully charged vs Lipo cell = 4.2v fully charged- draw your speed comparisons from that info.
They do need balancing though- its just good practice + they come with balance taps attached anyway so...
The only real noticeable difference will be that you need a 2p setup to output the same amount of punch as a normal 1p lipo pack, hence people using 6s2p setups when Life/ A123 cells are envolved (comparable to a 5s lipo setup of the same mah (~4000-5000 25c)).
The biggest advantage really is the ability to charge them in ~15mins vs ~1hour for lipos, assuming you have a suitable charger..
jpoprock
jpoprock's Avatar
11.24.2009, 01:37 PM
One more thing.... I've read thru this thread...and it appears I should maybe dip them in silicone to waterproof them. They likely won't get "soaked" though.
I'm sorta of clueless when it comes to all of the "data speak" about charging, discharging, amps, etc... The one dude on here (sorry, can't recall the name!), monitors the crap out of his charge, and posts all kinds of info. I'm hoping that getting that geeky isn't need really... because I run my batteries until the LVC kicks on, or until I'm done, then I will almost always top them off when I decide to run again. I always balance them, and never mess with discharging or anything like that. I run them, charge them, run them charge them. That's it! I sometimes will look at my Hyperion to see what the resistance is, just for kicks.
So..... should I be doing something different? Or is ignorance bliss?
jpoprock
jpoprock's Avatar
11.24.2009, 01:54 PM
Neil, so basically if my EVX-2 can only handle Lipo's in 2p config, that rule doesn't necc apply with Life packs because it's all about voltage, not how many cells.
Be gentle, cuz I'm really trying here.. and i know it's been discussed 10zillion times already... so in the case of the EVX2, rather than running a 4s2p config with an LVC on the BEC side... I could run a 2s Life pack on the BEC side, and a 3s Life pack on the other, to acheive the same results ala 16.5v's/5s2p?
At KA's site... they are selling a two pack 2s 4500 set for the Emaxx... but that's like 13.2v's. Unless I'm wrong in my understanding of what you've told me. And I'm gonna have to measure my compartment, cuz that 3s Life pack might not fit.
Thanks! Didn't mean to turn this into a "how to". I think i get it now...
11.24.2009, 02:28 PM
Not sure if the evx2 can handle 5s LiFe cells in series, that would be 18v fully charged...
I would go with a pair of the 2s2p 4500 packs. Plug them in like you would do with stick packs and go play. No need for a lvc, just stop when the performance dies off. It is a brushed truck, just leave it stock and enjoy it for what is is.
As for waterproofing the packs, dip them in plastidip, of use a small ziplock baggie. Unless you plan to submerge them in water, you really do not need them to be 100% waterproof.
I just checked the balance of the LiFe pack I have as I received it and it is almost perfect. I plan to get a setup together to run this, might be a week or so...
