Rivermaxx
11.22.2009, 11:53 PM
Originally Posted by chrismechanic View Post
alloy and nylon cogs are no good for brushless..too much power for them to take. do you run a mm combo then?
I have MMM esc with a real neu 2700 kv on 6s and have also used a 2200 kv castle neu on 6s. I have multiple 80+ mph passes on my g1 single speed tranny with a UE gear and stock nylon gear in a 11+ pound truck. I also have a few 69 mph doulble wheelys with the same set up.
The current version brushless erevo and new brushless maxx also has steel on nylon gears and has no problems on 6s. I know you are not making more power than me on 6s either. Its probably the shifting under power causing the failure. Single speeds are probably more reliable. Not to mention turning the punch control down to atleast 50 %. It will still do standing back flips with a blip of the throttle at that setting. Check out these gears they are made of titanium really light weight too.
