11.24.2009, 01:01 PM
What is the max power rating of both channels combined? Also, what is the max voltage it will take? Some of the higher output chargers will take voltages much higher to help reduce required current.
Once you know that, simply:
power_supply_amps=charger_watts/max_input_voltage/.8
The .8 is to account for charger inefficiency.
JThiessen
JThiessen's Avatar
11.24.2009, 02:31 PM
I bought the radio shack power supply - I think its 25W? Cheap, effective. havent ever taxed it chargeing 2 5S 5K packs at 1C.
11.24.2009, 02:44 PM
25w? Wow, a whopping 2.08A.
rabosi
11.24.2009, 02:52 PM
Yeah, 25w might as well go all out.
Bad Karma
11.24.2009, 06:37 PM
http://www.robotmarketplace.com/prod...C-DC-516W.html
Should handle more than enough...
Marvin
THE Paranoid Android
Marvin's Avatar
11.24.2009, 02:33 PM
Running on EXACTLY 12V, you'll need 37.5A (180W per port (so 360 total), divided by 0.8, divided by 12). 40A would be preferable to account for power supply capacitors aging over time.
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
