Gearing for bullitproof diffs ?
speedy
Gearing for bullitproof diffs ? - 11.27.2009, 04:58 AM
Hi !
I'm going to install the bullitproof diff gears in my flux ! and because they have a mutch lower gearing ratio compared to the stock gears,i'd like to know how i chould gear my flux runging on 6s offroad with stock tires ?
Freezebyte
11.27.2009, 12:07 PM
The gearing ratio isn't that much different, only a bit less acceleration for a bit more top end from what I could tell and its hard to notice.
thzero
11.27.2009, 12:55 PM
43/13 vs 29/9; that's 3.3 vs 3.2 gear ratios, so it ends up being a bit higher gear ratio.
speedy
11.27.2009, 01:00 PM
ok !
Chould i go fore a lower gearingthan 20/44t on 6s ? i mostly bash on gravel and grass and sone on snow
thzero
11.27.2009, 01:17 PM
Don't honestly think it'd make a noticeable difference. Its really about a .08 difference.
Originally Posted by speedy View Post
ok !
scarletboa
scarletboa's Avatar
11.27.2009, 06:34 PM
drop down to a 18t pinion if you're that concerned.
onetoo3
12.07.2009, 06:50 PM
hi
i have 43/13 with 52 robinson spur
big joe 40 is this good 13 pinion
would the new 29/9 be good
