11.28.2009, 03:17 PM
If the shafts are 5mm (or is it 6mm), then try pretty much any other standard output cups- Mike sells hardend steel ones I think. Driveshafts Im not sure about, though no doubt someone sells something suitable- custom dogbones per chance?..
JThiessen
JThiessen's Avatar
11.28.2009, 04:42 PM
I used the 1offRC TVP's. http://www.rc-monster.com/forum/showthread.php?t=23411
She has modified her part profile based on some of the things I found on the install, so they should fit great.
However, if I had to do it again, I'd likely go with FLM's.
I dont think you need to "upgrade" your drivetrain. Just reduce your punch control some, and maybe take an analytical look at how you drive. Do you land jumps with the throttle on? If so, how much? That can be one of the hardest things on a drive train, with the possible exception of standing backflips.
Gdot
12.10.2009, 02:06 PM
another couple here
http://www.gcmachine.ca/index.php/rcstuff/flux
