want more flex 4 the pede
HomeGrown
HomeGrown's Avatar
want more flex 4 the pede - 11.28.2009, 06:07 PM
so ive been messin round with the suspension on my pede and iwant to get more flex out of it but ilke the stance of a rustler wat can i do to get both but be strong enough to launch into the air and take a hard landing? i really want to do the wide pede conversion but still havent found a some what cheap way to do it. and neil i have read the thread on the wide pede conversion on byt..
BL Pede, Integy aluminum steering linkages, aluminum shock caps, RPM camber links.
Never Replace Always Upgrade!
Semi Pro
Semi Pro's Avatar
11.28.2009, 07:21 PM
put losi 8ight front shocks on it, they will handle any junp you can throw at a pede
HomeGrown
HomeGrown's Avatar
11.28.2009, 07:44 PM
that'll gimme more flex and the stance of a rustler?
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
11.28.2009, 07:53 PM
by flex do you mean suspension travel?
the pede is a pretty unstable truck as trucks go, but it is fun to play with.
like semi said.
get some losi 8 shocks on it. they are loads better!!
or you could get the traxxas big bore shocks and get some hot racing multi-rate springs, heavy for rear and medium for front, makes a huge difference!
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
11.28.2009, 08:20 PM
I use Ofna 1/8 buggy front shocks on the front and rear on my FLM Stampy, got the set of 4 for under $30.00 via Fleabay.
If you want the stance of a Rustler, you'll need shorter shocks than the stockers. Try Jato shocks ???
PedeBasher
PedeBasher's Avatar
11.28.2009, 10:18 PM
I think he would need to just lower the body, by using Rustler body mounts, to get a Rustler look. If you use Jato shocks all it will do is make the truck itself lower, and it will kill its ability to jump.
Did you know?
  Send a message via AIM to PedeBasher
HomeGrown
HomeGrown's Avatar
11.29.2009, 12:24 AM
pedebasher did u ever send those screws? curious... i dont want to kill my jumping abilities
PedeBasher
PedeBasher's Avatar
11.29.2009, 01:49 AM
Sh!t! I totally forgot dude. Sorry. Hope I didnt keep you at a halt in terms of running.
Just do what I said, and get some Losi shocks. The Rustler body mounts will really give it a sick stance.
Did you know?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
11.29.2009, 09:22 AM
Losi shocks with the bottom plastic cartridge style will not handle the bigger jumps as well as Associated T4 shocks !? Ben there, done that.
HomeGrown
HomeGrown's Avatar
11.29.2009, 02:50 PM
no u didnt pedebasher im waitin on batteries ill look into the body mounts thanks guys just let me know when u send them out so i can look for them
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
11.29.2009, 08:43 PM
Check this out, might be a cheap deal for a set of 4 ??
http://cgi.ebay.com/NEW-Team-Associa...item25576ff0cf
boostedg60rado
11.30.2009, 07:53 AM
t4 shocks are not going to handle jumping duty better than losi 8ight shocks. You are comparing a 1/8 scale shock to a 1/10 scale t4 shock. There is no comparison.
Though i used to love my t4 factory team shocks they are not better than losi 8ight shocks.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
11.30.2009, 09:07 AM
Dude, I know. I'm not a F-in idiot ?
But if the guy is one a budget, and wants scale appearance they would be the ticket.
It's only a suggestion.
HomeGrown
HomeGrown's Avatar
11.30.2009, 12:52 PM
Thanks Bondo! lol
t-maxxracer32
t-maxxracer32's Avatar
11.30.2009, 12:56 PM
you cant put rustler body mounts on the front of the pede because the servo is in the way
someone correct me if im wrong but i have the rusty body mount and just couldnt get it to fit without some wack modifications.
the rear body mount isnt a problem because you just neeed to take off that extender peice.
