12.04.2009, 01:10 AM
Originally Posted by Slowkrawl View Post
But then my worry is heat. If I were to coat it in anything, I'd wrap it up and plasti-dip it, however I think it would overheat due to no airflow and the fan wouldn't be able to even do it's job. I will see what I come up with and maybe post some pics. Here's to hoping I don't kill the speedy!
Edit:
Ahhh I just re-read your post. You mean coat everything except basically the fan? The fan looks like a perfect spot for water to get in to me....
Actually, coat everything up to the heatsink. As long as there is a seal between the heatsink and the coating, it's waterproof and there is no thermal penalty. Although, I personally would want to heatsink the BEC. It's switching but it does produce some heat.
