brushlessboy16
brushlessboy16's Avatar
12.07.2009, 06:51 PM
Another Big up date. scavenging around the shop today i was trying to figure out a way get the steering installed.. My main problem was finding bearings to fit in the steering assembly. The answer came in the form of bearings from an old transmission out of an electric duratrax evader... Next came the steering posts. Found a great match with Center differential mounting posts from an ofna Hyper 7 which i had lying in the junk box.. One end was drilled for m3, and one end was larger with an m4 opening. Hacked off the large end and it made perfect steering posts, they bolted into the stock location and work great.
Then i just had to dry fit the wheel tires and body!!
