shaunjohnson
i pwn nitro
shaunjohnson's Avatar
12.08.2009, 10:33 PM
Only if you don't know what you're doing .
I never had a hard time rebuilding shocks or diffs. I always use naptha to clean the old silicone oil from the shocks or diffs, wash it denatures alcohol and air dry them using my compressor.
you actually clean out the old oil!!??
i never do that, i thought it was too hard, so the best i do is cycle the piston up/down a lot and stick a rag in there as far as i can to get as much as i can out. then continue with the rest of the re-building.
