Scott711
Scott711's Avatar
02.02.2006, 12:58 AM
Originally Posted by sluggie24
Here's a question. I see alot of pics with the speed controllers mounted on a plate/bracket that is mounted to the motor mount. Is this something that is just home made by so many people or is it a manufactured product that I can get somewhere? If it is available where can I get it? Just looking for a good spot to put my 9920.
All you need is a stout piece of aluminum (1 or 2 mm max), a way to cut it or have it cut to size for you, and a bench vise and hammer to bend it. Drill your holes, stick on a thin piece of foam and you have a custom speed controller mount. I did the same thing with my battery mounts also, but then again I have access to a metal bandsaw and an ironworker to snap cut my pieces:) You can find the aluminum at the larger hardware stores. Good luck.
