The bottom mounting screw is in a single hole. The top screw slides along a slot that gives about 20mm of adjustment. 69T is the biggest spur that can be used, and the 26T pinion I have puts the motor right in the middle of the mount, leaving plenty of adjustment to gear up or down.
