I realized that the center rear dogbone on the extended chassis is the same size as the rear dogbones. I bent the center rear dogbone back as best I could and replaced it with on of the rear dogbones. Hopefully it holds up. If anyone still needs a rear center dogbone you can order a rear dogbone if you can't find a center one in stock.
