SunnyHouTX
SunnyHouTX's Avatar
12.21.2009, 12:09 AM
Originally Posted by Brow View Post
Gday Sunny,
What motor is in your FC? and what times are you running with that setup?
What benefits have you seen with the sensored setup?
Thanks
Brow
Hey Brow. Greetings down under!
I'm using MMPro with a Tekin Redline 3.5T motor on 2S in a new 1.05" wide tire/no wheelie bar class. ETs range from 1.8sec to 2.1sec. I like using it for the controlled launch off the line in Smart Sense mode where it starts off in sensored mode and then switches over to sensorless mode after a few feet.
Not in this funny car though since the class is limited to 12" wheelbase and under. A MM will be used in it instead.
