Joey
The Big Cheese
Joey's Avatar
05.22.2009, 12:49 PM
Thanks guys. I would have gone with a wing but it would be really hard with the way my towers are set up... Not sure the rear tower could handle some heavy landings on a wing. Its too bad I cant get the body lower, theres so much empty space between the top of the chassis and the top of the shell!
BitHed
05.22.2009, 10:09 PM
...looks great Joey...I look forward to you getting it driveable...
Joey
The Big Cheese
Joey's Avatar
05.29.2009, 06:26 PM
Well, here it is. I did this all late last night, and without proper masking tape. I only had 1" thick tape and no pinstriping tape. So the black line turned out not to be much of a smooth line, but more of a varying width, splattered paint looking line! But it worked out well because I like the look, gives it kind of a wild look instead of a perfect smooth line. The paints used were white, black and flourescent red-orange. Though it looks like pure orange to me (its even more orangy in person). I wish the color had a little more red in it but hey I cant complain for a first time paint job. It had so much flat orange I threw a bunch of decals on it, Im tempted to throw a bunch more on but I dont want to overdo it. The white on the truck bed is just some leftover material from the window masking sheet, I wanted to add some color in the rear, it was too orange!
EDIT: I just realized I had the camera set on "flourescent white balance" so the color is off a little. The orange is more rich and "pops" alot more in person.
brushlessboy16
brushlessboy16's Avatar
05.29.2009, 06:45 PM
Looks great joe :)
What else does it ned to run
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
05.29.2009, 07:04 PM
$.88 paint? LOL or did you go for the cans?
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
Joey
The Big Cheese
Joey's Avatar
05.29.2009, 07:23 PM
I just need the motor and esc now. Ive got crappy nimh batts to start with, Im going lipo though soon after I get the motor running.
The flourescent paint was $3.85, and the black and white were $1.00 each. All were spray cans. Not bad.
TruggyLuva
TruggyLuva's Avatar
06.02.2009, 09:17 PM
I like that paint job... The only sticker I would add is a big HPI one to the wing.
Thats so much better then the one color master peice that I thought was good
LSP | Stampede | Savage X | Rustler | B44
scarletboa
scarletboa's Avatar
06.03.2009, 12:54 AM
if you don't want to break the bank buying lipos and a charger, i recommend the zippy lipos and the $38 charger from hobbycity.com. i have some of the flightmax 25c 3s 5000mah packs and even with my massive 45x77mm motor, the packs have topped out at 102F when the ambient temp outside was 95F. they also maintain their balance well. i used a neighbor's high-end voltmeter (he's an electrician) and according to it, the charger charged the pack to 12.60 volts exactly and the cell voltages were 4.199, 4.196, 4.205. not bad considering the charger was dirt cheap.
Joey
The Big Cheese
Joey's Avatar
06.05.2009, 03:41 PM
I definitely had the zippys in mind, as well as one of those cheapo (but decent) chargers. Glad to hear they work well, aside from the low wattage output.
scarletboa
scarletboa's Avatar
06.05.2009, 04:29 PM
even that $140 hyperion charger has a 50watt limit. the turnigy 8 cell charger has a wattage limit of 150watts. you would be able to charge 6s lipos at 5a and still have almost 50watts to spare.
Joey
The Big Cheese
Joey's Avatar
06.06.2009, 02:19 PM
Are you talking about this one?
http://www.hobbycity.com/hobbycity/s...lancer/Charger
I thought you were talking about the ~$40 one. That is a great value at $80!
concreat
01.05.2010, 09:17 AM
(sorry if this has already been said...)
what center diff and center drive shafts are you using. i love what you have done and am thinking of going something similar.
