01.08.2010, 10:46 AM
If you are running 2s LiFe, I would either set the BEC to as low as possible (in the MMPro), or use an external one. There is ~1v dropout voltage needed. When a 2s Life is fresh (~6.6v), a 5.5v BEC is fine. But when under load and when they start to discharge, batt voltage will drop and may cause the BEC to cut out.
