02.04.2006, 09:04 PM
Quick question: The rc-monster site says the BK Wanderers require 5.5mm connectors, but the bk-electronics site says it takes 3.5mm connectors. Which is correct?
EDIT:
Something else; I was reading the warrior programming PDF at the bk-electronics site (http://www.bk-electronics.com/man_warrior_eng.pdf) and found this
Since the EMK brake does redirect braking energy into the batteries it is possible to produce voltage spikes much too high if using a power adapter. This will destroy controller, power adapter or both.
By "power adaptor", do they mean a BEC? Has anyone found this to be an issue?
