Freezebyte
01.11.2010, 08:45 PM
Of course, I'm guessing 3.50 might be a safe spot? Interesting, registering now!
It simply depends on your RAM design, type and settings, mobo maker , CPU make quality *yes, two exact SAME CPU's will overclock differently* the ability for your PSU to handle higher voltage draw, BIOS flexibility to change settings, ect...ect....
You may reach 4.0ghz with few issues or you may not even be able to overclock at all. Judging from the specs of your hardware, you might be able to get a decent OC but wether or not it will run stable is a whole nother issue entirely. Keep in mind that stock Intel heatsink fan units are crap for overclocking with, so there gonna suggest you spend money on a better HSF unit and likely a better power supply. I'm Freezebyte on both those forums FYI
rawfuls
roofles.
rawfuls's Avatar
01.11.2010, 08:47 PM
Yeah, I'm mostly worried about my PSU and Motherboard, Corsair XMS2 I have found is quite reliable, and quite good for now..
Freezebyte
01.11.2010, 08:49 PM
Corsair makes pretty good stuff, though their timings tend to suck in comparison to other makers. Your RAM will handle a light OC, but not much more then that, its not designed to be pushed hard. Memory, CPU's and mobo northbridges start running very warm when you start OC, heat is your enemy. Thats why some people will run liquid nitrogen in the most extreme overclock setups. Some do water cooling, others huge and loud fans or a peltier system or refridgeration or even AC cooling.
rawfuls
roofles.
rawfuls's Avatar
01.11.2010, 08:50 PM
Aww, okay, will do some researching! Thanks
simplechamp
simplechamp's Avatar
01.11.2010, 08:54 PM
Originally Posted by Freezebyte View Post
400FPS is basically useless as your monitor can't render that many frames a second anyway so I imagine your texture tearing is horrible. The human eye isn't capable of taking in anything beyond 60FPS and noticing a difference, for most peeps anyway
Totally agree. I always turn on V-Sync in the game settings or go edit it in the .ini file if I have to. I can't stand tearing. Anything above 60fps might as well be 60fps.
Freezebyte
01.11.2010, 08:55 PM
If you wanna see by what I mean extreme overclocking and cooling, check this out and this is several years old
[YOUTUBE]yyK3WlWTi10[/YOUTUBE]
Oil cooling is also becoming more popular
[YOUTUBE]pb4UumU6ee0[/YOUTUBE]
Freezebyte
01.11.2010, 08:56 PM
The problem with VSYNC though is typically if the computer isn't able to sustain near 60FPS, it will automatically jump down to 30FPS which equates to a very "stuttery" game experience depending on the game and hardware.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
01.11.2010, 10:08 PM
*updates* My 3.0GHz E8400 is now running at 4.124GHz! (464MHz x9)
