Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
riverat1540
riverat1540's Avatar
01.14.2010, 05:31 PM
Ok, D8, I'll say it again. Dont run your car while charging. It's just NOT needed. The draw from your charger is low enough that it will not drain your battery to a point that you will cause any damage to it. If you feel you must do something, buy a set of jumper cables just in case you do draw it down enough so that it doesn't start. If your drive home is 1/2 hour or so, your car will charge the battery enough so it will start again in the morning. IF then you have more issues with your battery, buy a new battery for it. I've charged lipos for three days straight without starting my truck, and it fired up fine.
Ditto it seems to me its time for a new battery if it is over 5yrs old, especially if u have cold winters
The optimas are the best but interstate has the greatest, if u really feel u need a large amp hour battery just buy the biggest one u can fit in your battery tray. I use my battery in my jeep just a stock interstate 850cca and never have drawn it down unless i leave my head lights on over night and a charger doesnt use near as much juice as them and i charge 6s at 5amps
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
