01.14.2010, 07:45 PM
Guess you failed at reading between the lines, or just on them:
If it's something that only Futaba can fix, we're all "up the creek".
Yes, ideally Castle should have repsonded to you, but maybe you just didnt take the hint- no solution to issue, so no responses/ time dedicated to fixing a problem that WOULD HAVE MADE THE ESC UNSAFE. Instead the engineers at castle got on with some more useful work. Emails can get lost or ignored, or overlooked even especially when the reply will be same as before ('wait for test results, or buy a different radio'). They do have a phone number you could ring also..
Nothing wrong with my mathes either, concidering the is only one rx type that doesnt work (sometimes) with the MMM, out of thousands & thousands of different models and makes etc etc...
You still havent said if you've contacted futaba to try and resolve the issue either?
Sorry you have a crappy radio dude, maybe you should concider upgrading to a better one, say 2.4ghz perhaps? ;)
