maxxdude1234
maxxdude1234's Avatar
02.05.2006, 06:56 PM
Originally Posted by Superemaxx89
unless wired parallel, more gp3700 won't give you more runtime. But you will get more power.
Serum and I had a long discussion about this, and adding more cells can increase runtime if geared down - so that the truck goes the same speed on 20cells as it did on 16cells. But if the gearing is kept the same, runtime will decrease (but speed obviously speed will increase).
Swift, your best bet is with lipos (lighter, bigger capacity, no voltage sag under load)
