Lauri
01.27.2010, 07:33 PM
Originally Posted by superek4 View Post
Only 2 cars out of 11 are ok.
I don't think its the mounting if all of our readings were weak only in the 3rd run. everyone mounted at the same place as their 1st and 2nd run.
Let them check the loop-antenna. This clearly shows that the problem is in the timing system and not in your car.
The AMB RC transponder works usually VERY WELL. The only thing is that it needs to have the voltage. Usually the transponder is the first thing to shut down if voltage drops (NiMH gets empty on nitro cars).
Maybe the track can put the loop above the track?
