e-rev project
02.02.2010, 12:39 AM
Converting a nitro to electric is very simple...I have done 6 in total
All you really need is a motor mount which you can buy here...Mike sells many different ones.
A battery tray which Mike sells here in many different sizes...or he will make you a custom tray to your desired specs....I have 5 custom trays from Mike. Drill a few holes in chassis to mount batt tray....done
convert to a single servo for steering and that is pretty much it
You can pick up used good rollers for around $ 200- w/spares, add motor mount and batt tray for another $ 90-, a good used radio system for another $ 125- or so, 1515 ccneu for another $ 150- and you should be in good shape.
Good truggy rollers to look for
1. mugen mbx6T or the older mbx5T
2. X-ray 8T-08 spec or 09 spec - 08 spec will be cheaper
3. Losi 2.0
Mike is also working on full conversion kits for some of the truggies as well..look in the RCM store under RCMonster parts
any reason for anti rc8 conv?
thanks
