zeropointbug
Z-Pinch racer
zeropointbug's Avatar
02.03.2010, 05:34 PM
Simply amazing, Capstone claims 80-90% efficiency for their lineup of turbines, that is simply fantastic. Now I assume yes, bu do they come with built in generator? If the 30kw unit is light enough, and cheap enough, I am for sure going to consider it for my next electric conversion, which will be an AWD Skyline model most likely, if not, then a 4WD truck, such as a Toyota Tacoma.
I have 4 extra Siemens AC drives sittings around, which are each capable of 200kW(270hp) if driven by the right Inverter/Controller. That should make any car or truck a blast to drive.
Using some sort of power buffer, be it ultra caps, preferably not as the gen. set would run 100% of the time then. Or a powerful durable battery such as an A123 pack, or if you have more cost effective cell please share.
lutach
lutach's Avatar
02.03.2010, 05:40 PM
Yes, the generator is built in. Did you get my last e-mail? I posted a link for a place that sells used 30Kw units. Contact Gaia on the cell, they are similar in format as the ones I sent you data on, but put out less power. I know there are plenty of good place in Canada as well.
lutach
lutach's Avatar
02.03.2010, 05:44 PM
Drawing 17 is a bit funny. I put a price there, but can't remember what it was for. That one has a rear drive only and I carried the twin induction idea to it. Drawing 19 was inspired on a Porsche.
Name:	Car Design17.jpg
ID:	8472   Click image for larger version
Name:	Car Design18.jpg
ID:	8473   Click image for larger version
Name:	Car Design19.jpg
Name:	Car Design20.jpg
lutach
lutach's Avatar
02.03.2010, 05:47 PM
As you can see AWD is something I like a lot.
Name:	Car Design21.jpg
ID:	8476   Click image for larger version
Name:	Car Design22.jpg
ID:	8477   Click image for larger version
Name:	Car Design23.jpg
Name:	Car Design24.jpg
lutach
lutach's Avatar
02.03.2010, 05:52 PM
Another mini van in drawing 25. Drawing 27 was also inspired by a Porsche, but not the rear section. I started to draw a front end in drawing 28, but never finished it.
Name:	Car Design25.jpg
ID:	8480   Click image for larger version
Name:	Car Design26.jpg
ID:	8481   Click image for larger version
Name:	Car Design27.jpg
Name:	Car Design28 not finished.jpg
lutach
lutach's Avatar
02.03.2010, 05:58 PM
I had the same issue in drawing 29, but the others I managed to finish them. They might look a bit crazy, but I can't draw at all. The pictures in my head is completely different from the drawings as I can visualize them in better detail. Drawing 32 shows a idea I had for a race car set up.
Name:	Car Design29 not finished.jpg
ID:	8484   Click image for larger version
Name:	Car Design30.jpg
ID:	8485   Click image for larger version
Name:	Car Design31.jpg
Name:	Car Design32.jpg
zeropointbug
Z-Pinch racer
hehe, nice sketches... I have made some pretty crude sketches of my car project as well a few years ago. I should find them, scan, and post em up.
lutach
lutach's Avatar
02.03.2010, 05:59 PM
Every time I look at them, I can't beleive I made them almost 20yrs ago. I wish I knew how to draw.
lutach
lutach's Avatar
02.03.2010, 06:03 PM
Now some engines and other goodies. All of them are flat style engines.
Name:	Engine and Rear End Suspension Design1.jpg
ID:	8488   Click image for larger version
Name:	Engine and Rear End Suspension Design2.jpg
ID:	8489   Click image for larger version
Name:	Engine design1.jpg
Name:	Engine design2.jpg
lutach
lutach's Avatar
02.03.2010, 06:05 PM
Now the last 2 are V style and I drew the twin induction idea.
Name:	Engine design3.jpg
ID:	8492   Click image for larger version
Name:	Engine design4.jpg
lutach
lutach's Avatar
02.03.2010, 06:07 PM
Ok, now let the insulting begin .
