Thread Tools Rating: Thread Rating: 24 votes, 4.83 average. Display Modes
SpeedAssault
SpeedAssault's Avatar
02.03.2010, 08:08 PM
UPDATES:
I tossed out the rear spool and put in 7k oil.
painted the wheels silver
Still working on the Sway bar system.
Took it for a spin and it drove really well until one rear axle shaft split open then the front wheels were unloading like crazy !
SO i need some stronger shafts as I see the joints are getting sloppy as well
thzero
02.03.2010, 08:40 PM
Looks good. :)
littleazn248
03.06.2010, 02:58 AM
UPDATES:
Im really curious have you adjusted the position of your upper arms? They dont seem to be parallel with your upper arms
SpeedAssault
03.06.2010, 03:25 PM
I have been thinking of that actually, brainstorming how I can make the lowers and uppers level. It's much easier to just make the uppers level.
Do you think I just need to level the uppers ?
if you look at the rear (black uppers) they are much more slanted.
SpeedAssault
03.07.2010, 10:21 PM
Anybody have suggestions on Shock oil weight with soft or hard springs ?
I have ot setup so the suspension holds the car up but it seems to stiff.
Finally built my Lipo Tray box
3/16 Delrin sheet with mouse padd cut up and other high density foam to help cushion should impact accur.
