02.04.2010, 07:58 PM
why without a body? you lose all aerodynamics without it. and your drag would go thru the roof...(lol sounds out of context)
i would say thick oil all around and as low as possible without rubbing bottom..and def limit your droop.. i would go with zero degrees for toe and camber as you need all the foward traction you can get. and have the front a little lower than the rear to help with down force.. if you keep it level when the truck squats on acceleration you will lose some traction on the front.
