More speed and power than the hv don't narrow it down none. My 9xl has more power than two of the hv maxxes. I get more run time as well to. Speed is above the hv. Your going to run no less than 14 cells maybe 16. 7xl or a 8xl would be real nice. Determine how much runtime you want. 7xl is not to long about 10min or so depends on driving style. 8xl will run longer but a touch less speed.
Rc-Monster Buy here
I think i will go with the 9xl on 16 cells and maybe add more cells later on and use a Warrior 9920. One thing i don't like about the HV it seems like it has no brakes at all is the 9920 better at braking?
What is RC-Car Software? The info on the 9920 says it has a bec do i still need to buy one?
Does anyone else sell the 9920 and the 9xl that have it in stock?
Money wise i'd spend 500 bucks to get a good setup, i really want a good small Controller.
That is something like the maximum continuous amps. A motor can pull more than that number of amps in a short spike (from high track, for example), but normally will pull much less.
