junkman
02.07.2010, 12:56 PM
I've messed with/fixed a couple of the tornado 1/10 buggies. And honestly they really havn't been too terrible. They actually run pretty good. The diffs, at least the ring and pinion were metal in these, but have seen a couple of them strip, so the clearance must be off or just cheap metal. About the only other problem has been the knuckles get worn and will pop off the pivot balls, the radio equipment leaves a little to be desired as well. But for $120 rtr car. I guess you really can't expect too much.
