02.08.2010, 03:29 AM
Pic of Arctik's G3R people are crying for
JERRY2KONE SUPERMAXX
Thats ok -
02.08.2010, 03:41 AM
Originally Posted by _paralyzed_
thanks for quoting me Linc. Sorry for the threadjack Jerry. I went to my room and pouted, I feel much better now.
That is OK Harold. I was feeling almost as disappointed as you when I saw that it was not the same thing. Of course you are feeling bad because you sold your only original unit. Mike assures me that it will work just fine with a few little tweeks, so we shall see how it goes. I have two comming my way. We all needed to take a step back and relaxe just a bit. If it works out, then it works out. If not then we will rant and rave about the short commings of the newly designed unit at that time and let Mike deal with it. Life is good Harold.
02.08.2010, 12:20 PM
Ok - quoting you again!!!!! Does that mount look bent to anyone else? I know optical illusions can happend with digital photos, but something is out of alignment there.....
Second, in the pic in the RCM store, the small mount doesn't have holes in the bottom - are we going to have to drill and tap that to suit? Not a problem for me, but just wanted clarification.
02.08.2010, 05:04 PM
I'm pretty sure I remember Chris saying that mount is bent.
02.08.2010, 06:00 PM
i was thinking the exact same thing when i saw that picture.
02.08.2010, 06:13 PM
yep, it's bent. he bashed it good.
02.08.2010, 06:15 PM
also looks like its bent as if he had a hard flat landing? the pinion and the spur are a dead give away and the motor looks like a 1515, which is small in the world of monster trucks.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
Its time -
02.09.2010, 09:56 AM
Let the games begin. I just received notification that my two center diff/motor mounts have shipped.
Multi Tasking
02.09.2010, 01:43 PM
Wohoo for Jerry!
02.09.2010, 01:59 PM
I believe it was one inverted landing too many...
That's All Folks!
02.09.2010, 04:15 PM
The whiners are obviously inexperienced hobbyists.
I say those look great, may order one myself, just 'cause.
02.10.2010, 06:31 AM
i think inexperienced hobbyists goes for everyone on this site lol
02.10.2010, 01:55 PM
I wonder if Mike could make a thicker motor mount for 22 series lehner. I have a 2250 11 turn (1184kv) that would run perfect with a 20/44 and 5s
That's All Folks!
02.10.2010, 04:19 PM
What, that one not thick enough? I have one that is thick enough... better send me the motor  . And I would run that motor at least on 6s.
02.11.2010, 12:05 AM
Na, I need it to embarrass the truggies.
Mike, any chance you could do a limited run of the old two gear tranny? I know in stock form it wouldn't work on a G2R revo. But using the design from kazuaki on his mini E-revo
http://www.rc-monster.com/forum/showthread.php?t=23804 Post #2, I'm sure it can be done with this mount setup. Its either this or the fastlane Mounts Hillbilly-rigged to fit in a G2R, Personally, I'd rather run a monster product
