02.10.2010, 10:28 AM
Going up on pinion will increase speed assuming you are using the same spur gear. The 8xl you are running is a hot motor anyway...so keeping any Feigao cool is a chore at times. Try running a smaller spur and see what happens if you can't change to a smaller pinion
what vehicle is this set up in...what batts are you running..more info will help as well.
