HotnCold
HotnCold's Avatar
02.08.2006, 02:40 PM
Dual element bulbs - ( 1157 automotive i believe ) are the ones to use - and one bulb is equal to 2 amps - so if you assemble 10 of these bulbs you have a 20 amp discharger - if you do this and you discharge your packs this way and you are not using a voltage cutoff device in line - then be sure to remove the battery when all the lights dim - not go out completely.. Hope this helps..
Hows that "Hope and Change" working out for Ya???
