02.13.2010, 08:30 AM
looking good!
Sower
Sower's Avatar
02.13.2010, 11:07 AM
Looks awesome!
MBX6T Tekin RX8 5s Neuenergy
www.robsower.com
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
02.13.2010, 12:59 PM
RC8T comes with extended hubs so you can run standard 0 offset rims.
Why run a kyosho spur gear? Associated makes plastic spurs that bolt right up. I run a 50T associated plastic spur on mine
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
02.13.2010, 03:05 PM
George - Stock hubs, haven't ordered anything from Tekin yet. I'm waiting to see if they get my RX8 finished. I'll call monday and ask. If they aren't done, I'll order a RX8 if they can get it to me before the weekend. I'm anxious to run this truck!
Thanks for the compliments Magman and Sower I've wanted a RC8T for a long time.
I had the 46T spur from a previous build. Plus it eliminates the lower plate and is a slightly lower gear ratio, which I'll need. This spur bolts up too, for anyone that wanted to know. I think I have another one laying around somewhere.
:D
e-rev project
02.13.2010, 09:09 PM
build question, how many spacers did you use for the servo , just the alum rcm one or that plus extra, with just the rcm alum one the front drive shaft is very close less than 1mm, thanks
gtxracer
gtxracer's Avatar
02.13.2010, 09:24 PM
I used just the aluminum RCM spacers. If you put the servo on top of the plate and the spaces below it between the servo mounts, you should be fine. Yes it's close. Close tolerances means good engineering!
:D
02.13.2010, 11:41 PM
Me too...except I love my mbx5t and can not justify having 2 truggies to bash with
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
02.14.2010, 12:24 AM
I only used the spacers included as well and no problems.
gtxracer
gtxracer's Avatar
02.14.2010, 01:08 AM
The 5T was awesome, I'd like to try a 6T someday too.
Oh, and I picked up a Mamba Max Pro tonight to serve duty until my RX8 gets back. I plan to put it in a SC type of truck whenever I get one. I can't get it to arm on 4s though...I have no idea why.
:D
gtxracer
gtxracer's Avatar
02.14.2010, 01:58 AM
Had to wire up a Rx pack with the MMP to get it to arm. Got it going and WOW it is FAST! Much faster than I had my Mugen geared, not sure how that will do at the track but we'll see. I would love to let it rip on a bigger track...or better yet, with a bigger pinion and some foams or street tires. I bet I could hit 70
:D
Sower
Sower's Avatar
02.14.2010, 02:11 AM
I would love to try the 6T - that thing looks awesome.
www.robsower.com
gtxracer
gtxracer's Avatar
02.18.2010, 12:57 AM
More pics...
After wet pavement run
:D
