el tomaso
02.16.2010, 07:35 AM
Thanks for your help guys!
Finally, 10t was IT Temps were better, acceleration(sp?) was extreme, AND speed was actually not much less
I was starting to worry about this little Mega, but it seems I got a lot of motor for my ~70 dollars!
To further lower motor temps I changed the timing from 5 to 0, changed the punch control from 70% to 100%, and also remembered to lower the brake amount to 20% after installing the brake servo, that being the point of the mech brake after all.
Only problem now is that I had to remove the front chassis brace to get a good mesh with the 10t. I will have to make other stiffening arangements
Thomas G
